There should be a way to add layers in a pdf on blue beam studio
to have to set them all up sheet by sheet then upload them is very time consuming each time a new sheet is added or if someone else adds sheet
Hi fellow Bluebeam User, To be clear, there are two parts to Studio - Projects and Sessions. I believe that you are referring to Sessions. Part of the rules for Studio Session is that the PDF cant be edited once its in the Session, having more flexibility is a good feature request, but what can you do today? Have you used the Batch functions that are in the Complete version? There is a Batch Script that will allow you to add Layers to as many drawings as you need in preparation to load up into a Studio Session. The way you do this is to create a Script that imports a "Master PDF" that contains ALL the Layers that you require, into the PDFs that you want to load up into Studio Session, then delete the Master PDF, leaving your Layers behind.Here is the Script: InsertPages(0,"{add in your Master PDF location here}\Master_PDF.pdf", false, false, false, true, false) PageDelete(1) The one true value is (please check) the option (boolean) to import the Master PDFs Layers into your PDFs that are to be uploaded into Studio Sessions. Let me know how you go.
I add the layers prior, i appreciate the input I wanted to see if there was ever a way to add layers once in a studio session
Shanoc, the extreme lockdown of options in bluebeam sessions is a feature great for collaborating with outsiders to your organization, but users have wanted for years to be able to reduce those restrictions and collaborate internally on one PDF, with the ability to edit others markups and you know, use the program for all its features.
hello, thank you for your response It shows my subscription is CORE for Revu 21 Version 21.6 x64 Core This means im not able to do the script, I have been creating the layers each time i have to upload to studio I am not sure how to make a template for just the layers and import them easier then re created them each time
Is there anyway to customize keyboard short cuts for say the highlighter function? I would like to be able to have these for different colors.
Creating PDFS stopped working. Any ideas to fix?
I have a document that I have in Studio. If I open it on my ipad. Sign it. Save to file. Signature is not there when I open the file on my pc? Any ideas what is happening?
been getting a "file download error" on iCloud App. it wasn't an issue before but now some of the previous sessions is now not loading. it loads on desktop but not on the app. any idea what's causing the issue?
Good Morning ALl Just looking to get set up for further investing in my tool chest with symbols for Watermain, storm, and Sanitary symbols for when doing takeoffs for Civil construction. If you have any you would share or any iodeas it would be great. Unfrotunaltey not the best artist of the group, so freehand on the fly…
Why in this new version the command "offset" is disabled? It saved me a lot of time. How can I enable it again? My Revu plan is complete
Hello! 2-part question: 1. Is there a method, after marking up plans, that I can Batch Change my scaled Dimensions from Ft-IN to IN? As I export to a workbook,I need to convert dimensions for formula use 2. Is there a better formatting or setup for markups, knowing that I will be exporting the data for take-offs? Thank you
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
