I am very new to BlueBeam, I have managed to insert my Professional engineer stamp, I need to insert the date and signature on the stamp, meaning to layover the date and signature on the stamp in a certain area, and all should be visible.
Welcome to Bluebeam.
What you're going to need to do is learn how to make a dynamic stamp. There are videos and other tutorials on the subject, so it shouldn't be too hard to find.
The stamp will have a small amount of JavaScript in it, which will allow you to place those variables.
Good luck
Thank you Doug!
You can make the stamp without using JavaScript by using Dynamic Fill. Just add a text box to the stamp and choose "Date" from the "Dynamic" dropdown. See the example below.
Note: The date shown will be the date the stamp is applied, and it can't be changed.
Hope this helps.
Another thing to remember when stamping your engineer's seal/stamp onto PDF's is to double check what your regulatory body allows in regards to signing/stamping digital documents. For instance both APEGA & EGBC seem to recommend utilizing Notarius for their digital stamps:APEGA Digital SignaturesNotarius link for APEGA If you look under PRactice Advisor FAQ on the EGBC site (Specifically the 2nd point on sealing documents) reads:
"No, a scanned image of your seal, signature, and date, cannot be applied. However, the image of the seal can be scanned and applied to a document, which is then printed, signed, and dated. The legal requirement is that the signature is live.
For more information on sealing requirements please read the Quality Management Guides."
https://www.egbc.ca/registrants/practice-resources/practice-advice-program/practice-advisor-faqs I believe that you can still utilize Bluebeam for this - the signing registrant for our company manages it so if there's any confusion I can reach out to inquire further details regarding how they have it setup.
Just a FYI @David Kozuchar - were you aware that Bluebeam Stapler removes the digital signature from previously signed documents from Notarius / Consign-O?
CAn we export form Bluebeam to DXF. If not any way we can export the lines to be used in anlaysis software
Some of the consultant drawings I receive have a protected scale and when taking measurement and areas it doesn`t show up in the markup list. Also the drawing is blued out. Is there away around this Many thanks Murray
I've been trying to find anything related to this, but all I see is default tool 'settings' but I want to change the tool, not settings of the tool. The default selected now is the pan tool but my most used tool is the select text tool and when I open a new PDF or have multiple opened and then I close one, Revu will change…
Hello, I have used the Grab feature for years and it is one of my most frequently used tools. Recently, however, when I grab from one drawing and paste into another, the file size increases from around 1 MB to 2 GB. If I switch off “Take Vector Snapshots”, it resolves the file size issue and the drawing size hardly…
When working on a file, Bluebeam will freeze then shut down. It's been happening quite frequently. Why is this happening?
As part of preliminary estimating for roadway projects I have created a custom toolbox for area, length and count items. I can change the color. Is there a way to change the icon to something like SW for sidewalk area? I have the measuring tools set up with custom labels and layers to facilitate review and quantity total…
Hello, Can I import Chets Tool Items from Excel. I've a list of items in Excel (number, description, m, m2, m3 of Pc) I've to measure. Can I import it to Tool Chest. Thanks.
Good afternoon, I want to create a Tool-Chest component in "Tool Chest" that automatically numbers, e.g., W001, W002, W003, W004, ... and measures the area. It should place this on the plan-view with number W001 and the area. And then also place this number W001 in the Marksup list so that the link between a specific wall…
Hello! Today when uploading a capture from a screenshot, the image sets at 3D, does anyone know how to make the capture images to set at 2D? Thanks in advance
