Hello - Looking to find an expert who understands scripting and what scripts work best with Bluebeam. Any suggestions?
I believe @Doug McLean is well versed in scripts.
Thank you @Jes Stafford !
I'm not the strongest at it. The Scripts in Revu that I know are the very basic ones that you can find under the Help Menu in the Bluebeam Extreme Script Reference. If you're looking more for JavaScript, like you would use in stamps and Forms, then I can direct you to others who are WAY better than I am.
Unfortunately the scripting native to BB is very limited, as are their implementations of Javascript. To some degree I understand that this is a deliberate choice for InfoSEC. That being said there are a lot of options out there so if you want to reach out and share your desired functionality I might be able to help.
Thank you Nick.
I review drawings looking for errors. If I find an error, I color the bookmark RED. My ideal goal would be for the bookmark to automatically turn red if there is a comment.
Is it possible to extract data from multiple pre-defined locations on hundreds of scanned PDF's and extract/export to excel? Scanned pdf's would have same form and locations of information. I have been able to extract all of information on pages (creates mess) but no way to capture just certain fields/locations?
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad?
Hi!, I'm a senior technician in an architect office, and I regurlarly do some site surveillance and dificiency reports. I am looking for an app on a tablet to consult plans (pdf format ideally), annotate them with comments (ideally speak-to-text) that will generat a list of comments with a "pin" on the pdf plan localising…
Curious if anyone adds a "time" or "man hours" columns in their markups list when doing takeoff. I have some ideas but unsure if they will actually be useful. For example: 10 LF of footing = 1 man hour. Does anyone have any tips on adding custom columns on their markups for time? I already utilize it for material cost per…
Populous is hiring for a Computational Designer that sits on our Global Digital team. Link below to apply today! https://populous.com/careers?gnk=job&gni=8a78879e9c9ca640019cbacb46066ef9&gns=Recruiter
Good Morning Has anyone successfully imported their take-off from Bluebeam via excel into Trimble Contract Master Estimation software and have you managed to link an item in that take off to your database item?
If you choose an area and set the color, line weight and so on, then click out of measurement you have to then go back and redo all the particulars for that item that you are trying to take off. Can this be remedied? Onscreen allows the user to set a group of items to use repeatedly throughout a set of drawings (color,…
Is there any way to autogenerate markups in Bluebeam instead of manually tracing every area and perimeter? I bid multiple jobs a week, and these "robotic" takeoffs are a huge bottleneck. Does Bluebeam have an AI feature to auto-detect these boundaries and generate the markups? Manually tracing miles of sidewalk, asphalt,…
Imagine placing a door symbol and Revu automatically attaching a mini BOQ for leaf, frame, hardware and labor, all rolling up into one smart cost object that updates as you copy or move it.
