I have a document with over 30 text boxes that are polygon shaped. I need to keep the text the same and just change all the text boxes at once to a rectangle shape. Is there any option to do this? Any help would be greatly appreciated.
Here is a visual of what I'm working with.
I was going to say "Select them all in the markup list" but if you pick more than one, you can no longer change the shape. 🤔
Unfortunately, I tried all methods I know of to select multiple markups and once you select more than one, the shape selection option disappears. This would be a good suggestion for improvements to REVU.
As mentioned, the selector disappears with multiple markups. One thing you could try is to change one of the hexagons to the shape that you'd prefer. Then, right-click the new shape and choose Format Painter.
Your cursor will become a paintbrush. You will be able to click the remaining shapes and have them change.
I have never noticed this in the right-click menu and I have been in there a million times!
I am very new to BlueBeam, I have managed to insert my Professional engineer stamp, I need to insert the date and signature on the stamp, meaning to layover the date and signature on the stamp in a certain area, and all should be visible.
Hi all. I am a relatively new user to Revu(CORE). I am able to edit .pdf's with lines, shapes, lengths, etc. However, I've found out that a pdf (multiple times) that has text that I want to edit in Revu won't allow me to do that. Why can I edit lines, but not text? I'm a little flummoxed because I want to get of Adobe…
It would be awesome if there was a vba add in so that we could use vba macros to combine pdfs, without needing to save, open bluebeam and then combine files there.
I just moved to Bluebeam a couple months ago and I am very impressed with the functions it offers. I am working on a job with multiple people and am curious if we place a file on the network can multiple people get in the doc at the same time with read/write ability? I am thinking "Studio Sessions" might be the path i need…
In the Markups list, whether applying a filter or not, the length of a line does not show up. I would like to export to excel all the lines with length property, but in the markups list the length is not shown. Are the two "length" properties the same? Is this a bug? Thanks
Does anyone know hw to turn off this feature (brown help box) that lets you know the highlight is in use. toggling between different documents or screens, it moves every time you move documents. It is very distracting and moves your page.
In the past we were able to require fields to be filled out before an individual could save the form. Now, if I make a field required it only puts a red thick border around it. This allows individuals to skip a field and submit a form with missing information. It is driving me crazy. Someone please advise. Thank you! :)
I use custom stamps regularly and find panning up and down in the dropdown to be annoying since the icon to pan up or down is so small and when my pointer goes past it the drop down disappears, then I need to find my stamp again..! Please fix..
Hi Bluebeam Team and Community, I often use Dark Mode when reading long documents in Revu, as it’s much easier on my eyes. However, depending on the document content, I find myself frequently switching back and forth between Dark Mode and regular mode. Right now, I have to navigate through Revu > Preferences each time to…
Is there a way to disable the "(1 of XX)" part of the navigation bar? I manage pdf's that have page labels formatted "PID-xxx". The actual count of a page in the pdf, meaning the "(4 of 11)" part below, is irrelevant to our document structure. When navigating to a page, I use only the page label to get to it ("PID-869" in…
