Hi All,
We are changing the company style guide and stepping though updating everything to match. I am wondering if it's possible to change/specify the font used when creating a batch summary in PDF format? A long shot I know!
Thanks Elizabeth
@ElizabethOliver I just took a look and I'm fairly certain that you can't choose a font for the Markup Summaries right now.
I do however think that is a great idea, and I would encourage you to pitch it in the Product Feedback forum where other people can upvote it and maybe talk about why it would be valuable to them. More upvotes means more attention from Bluebeam, means a better chance at getting implemented.
Product Feedback - Bluebeam Community
@nateharris Thanks for the reply and suggestion.
Is there a way to batch hyperlink a range of pages instead of the entire document? I have a 325 page document. Within that document are sets. There is an overall page with area references to that set. That set is page 58-78. I know I could pull the set out and do it, then reinsert. Just wondering if there was an easier way.
