how to i change the line density when using the measuring tool? when i pull a measurement i click and the measurement stays as a thin blue line and not a thicker line
Line width will change that.
When opening PDF's from file explorer the Preview and opening the PDF lags so bad, even up 30 seconds when it normally would take a few seconds to open.
We have callout tool set up with certain size of leader. Sometimes, I started with text box tool and need to add a leader later. The default leader size shows quite big. The font size is actually the same, just callout tool setting is 50% of the font size while the text box setting is auto. I can fix it. But I want to set…
What is the best method to track version history. What I am looking to accomplish is having a combined set of my submittals to a general contractor that when they respond with AAN or R&R I can add that to the combined set and make it the new version of that set. When I want to look at past versions I can toggle between the…
I'm testing out 21.9 at the moment and have come across something which I'm not sure if it is a fault for everyone or just on my computer. Basically, I'm trying to export some tables to Excel but no details are added to the newly created file. Is anyone else experiencing this???
The gear on the left side of the screen toolbar use to have all of my edit tools (color, font, line size, etc.…) Now it is just file attachments and file properties and the edit tool are across the top toolbar. What did I do to change it and how to I fix it?
What is the schedule for enabling Cloud to allow batch stamping and signing of pdfs along with digital signatures as is available in Revu on Windows? It would be most helpful to be able to access, stamp, and sign drawings on an ipad instead of carrying laptops.
Hello everyone, i was new to bluebeam. And i found it very depressing that everytime i calibrate my scale, it was 0.093138cm=112.5mm and everytime i apply this scale. the scale turns into 9.313.815cm=11.250mm. can anyone help me with this. Thanks in advance.
I used to use the "paint can" fill option all the time when organizing my PDF's, and that icon disappeared a couple years ago. Did it get changed or modified? Is there an alternative that will do a similar task?
Is this a way to not have leaders attach to the top and bottom items like text, only to the left and right sides?
