How do I default certain colors and degrees of shading? For example, if I need a text box it defaults to red at 100% also the text color. When I need a text box, I need it yellow at 40% and the text black.
Awesome! Thank you!!
No problem. However, it appears you accepted your comment as the accepted answer instead of mine. Usually I wouldn't care but when I checked for an update, it hid my answer because it had defaulted to display "accepted answers". That "tab" is not obvious so someone new would be pretty confused that you praised yourself 😁
Hi All, I need to send a share link of the Revised Arch. sheets in my Set to the printer. BB AI chatbot pointed me to Sets/Publish/Combine then select the option to "include only revised sheets". Sadly this option doesn't exist in my Combine window. Can anyone tell me where to find it or if there is another way to create…
I am opening Revu 20.3 extreme. It opens however it does not allow me to perform any functions. I have uninstalled and reinstalled it. Same issue. When i open revu 20.3, the window that says recover unsaved changes opens in the middle of the software screen. The item that it refers to was deleted from my pc. I also deleted…
I recently build a testing report for my field representatives that includes a javascript for some basic calculations. I wanted the form as easy as possible for my older field reps so I wrote a straightforward javascript that will automatically highlight, make bold, and show the result they are after. This form works…
Besteht die Möglichkeit, wenn ich die Deckenfläche markiere /ausmesse, dass gleichzeitig der Umfang angezeigt wird. Es ist doch erheblich aufweniger, wenn ich zuerst die Deckenfläche markiere und die m2 erhalte und dann nochmals die gleiche Deckenfläche abklicke um den Umfang des Randprofiles zu erhalten. Das könnte man…
How do I export all pdfs into one? I am going in a field visit tomorrow and I am trying to use a revu project in the field.
I have a user that as of this morning is experiencing an issue with typing spaces into any markup text entry field. Text boxes, Callouts, comments etc. The behavior is a bit hard to describe so bare with me. If the preceding character to the typed space is a letter or most symbols then the space does not appear normally…
Just recently I get this dialog box when using File/Open pulldown. I can use the Open From Disk button to get to the local server our files are stored. Does anyone know how this default changed or how to change it back? Thanks!
Why all of sudden are my files loading slow regardless of how I open them and how I change my hardware or rendering settings. I have been using Bluebeam for years with no issues like this until directly after the update. Below is the version I have…any help or insight would be appreciated..
Anyone else having issues with applying a markup filter and the drawings aren't graying out the filtered-out markups? Is that an error or an update to the latest version? I've got my filtered annotation dimmed to 40%
