If this preference isn't already available, i would like an option to have the highlighter tool simply as a free form tool, and not one that automatically attached itself to text.
Use the Pen tool and select "Highlight" under the Line Width.
@Rob7603 The highlighter tool can be used freehand if there is no text underneath. You can also override text mode and draw free-form highlights over a text area by holding CTRL while you click and drag.
Hope that helps! We also have a lesson on essential markup tools in Bluebeam University if you're interested in learning more about the different ways you can use markup tools in Revu. There's a video that specifically goes over the highlight tool and the different ways you can use it in the lesson "Essential Markup Tools" in our Revu Essentials course.
@Luke Shiras I like your answer too!
Holding Ctrl as suggested will temporarily override the text highlighting, and there is a Preference setting you can disable to completely turn this off.
Go into Revu's Preferences (Ctrl+K), select Windows on the left, then on the Tablet tab, un-check "Enable Text Highlighting" and click OK.
With this disabled it will no longer recognize and try to select the text in PDFs when highlighting. You can also hold the shift key while drawing a free-hand highlight to draw a straight line.
I have added our org SharePoint to Bluebeam Cloud (website) and I can see folders as I would expect. When I add my org OneDrive account to Bluebeam Cloud I see OneDrive and PersonalCacheLibrary folders show, if I click on OneDrive, it says "Something went wrong. Please try again." Never works, and I opened a ticket and…
I found this support article, but I don't see the options shown in the screenshot to send to Cloud. At the bottom of the tool set menu I only see Manage Tool Sets, there's no Send Tool Sets to Bluebeam Cloud.
Reposting this from Peer Support to USBUG: Since upgrading to 21.6.1, it seems I have to rearrange order of the tabs on each BB OPEN. I commonly start with about half a dozen tabs open for a couple of most active projects. I like to have them in order of Project 1 Specs, Project 1 CA Set, Project 1 Revisions, Project 2…
BB crashed and I had added/edited dozens of tools and when I logged back in many of the toolsets were not showing in my profile or in the toolset list (so not hidden). Any ideas? And when I tried importing it said they already existed….
I would like to remove and save approx. 10 pdfs from a studio session to condense the list to the most current files. The process of deleting individual files and saving a local copy is rather tedious. Is there a way to streamline the process?
Long post for context: Yesterday I was trying to compare a revised architectural to realize that the floor plan has shifted in both the X and Y, so this morning I did a page snapshot. What I would like to know is, is there a way to snap to a point on the snapshot and move it to a point on the drawing?
Introduce a return function in Bluebeam! For example; Let's say there are annotations on the floor plan that have hyperlinks that take you to that annotated elevation and from there you click another annotation marker on the elevations that takes you to that detail and if you want to go back, you either have to remember…
Hi Bluebeam. Isn't it possible for you to make a continuous measurement like the one shown? regards Claus
Hi, I want to ask here if Bluebeam product support creating symbolic link for the studio session files being stored at C disk. The need arises because session files are taking up a large space on C disk. I am looking for options to shift this data to other drives and make up space.
Every Time I load a document, it says this document has a protected scale and won't let me measure anything. Anyone have any suggestions. Thanks
