Most of this is possible already, just takes some tricks. I don't know if I have time today to get to all of them, but perhaps others will contribute to the list. First one: Keyboard Shortcuts Start with clicking on "Revu" in the top left and select "Keyboard Shortcuts", from here you can search or scroll down the list to find the command you want, then enter in your desired shortcut. Sketch to Scale tools are listed as an option:
If you want to see the default assigned keyboard shortcuts, those can be found by to the Help menu at the top, and selecting "Keyboard Shortcuts Guide" which provides a nice printable PDF of all of the default shortcuts. If you customize them in the step above, they will not be updated in the guide, but you can always make your own copy of the guide and edit the test with Revu to updated it yourself!
I'll jump in with one @Jason A
@brozier to "Subtract area from a fill region (e.g., make a donut shaped fill region)" use the "Cutout Tools":
Hope this helps! 😎
Both @Jason A and @David Cutler make excellent points. Another option you may consider is a Programable mouse or maybe even a Stream Deck.
Thank you!
Second one: Count objects from a selection (show how many are selected in the properties panel) As a fellow Autodesk user, having the number of selected items in the properties panel is a handy thing. Revu does not give a number, it just says "Multiple Properties". I have not been able to find a workflow that matches the Autodesk count. This is an inefficient hack, but it works. Create a tool with a subject of "TempCount". For example I used a pink Cloud for this. Then I use that Cloud to highlight the objects I want to count. From there, open the Markups list, filter to isolate the "TempCount" and then you'll see the number in parenthesis.
Ooh very creative! Thanks!
Bluebeam, can you just add this info to the Properties panel? :)
Fourth One: Ability to have two different studio review sessions open at once (without having to log in again every 5 minutes) There's a couple ways to achieve this: Have one session in the desktop Revu, and another on web app.
Or run a 2nd instance of Revu. With one Revu up and running, simply launch it again from the icon for a separate independent instance. There are likely other ways as well, but the ones above have worked in my testing.
Thanks!
