Hello,
Just a really simple question really. How do you add a border around a document in bluebeam? I've looked everywhere and can't seem to find the answer
A good question @Stephen Brewitt!
Unfortunately I don't know that Revu has a "border" feature.
What I've done, which seems to do the trick, is draw my own using a rectangle tool. You can set the line weight and color as you like. To keep it from being moved around by others you can then flatten the markup so that it stays as a permanent feature.
I've taken this a step further and created a plan sheet "template" that has a border and a simple title block with our company logo. I use these for sketching in Revu and keep a few 11x17 sheets printed for hand sketches.
Hope this helps. 😎
Make a stamp with the border the way you want.
