I have talked with tech support about this current feature a while ago but there is a feature / command to cut and paste an entire files red marks from one file into another exact copy of that file, just transferring red marks.
Only issue was, it is not turned on for use in a bluebeam session. I was told Bluebeam might look into it if enough people brought it up but I think most of the Bluebeam Users may not be aware of this immense time saving command. We just need it to work in a session.
Of course you would still need to go back into a session file and fiddle with your markups to fix where they may have stepped on others comments but that's part of the deal and should be expected. You already fix these things when you do a single page cut and paste already.
So, I implore Bluebeam, and with Community support, to activate this major time saver command for use in sessions.
The world of Consultants, Architects, and Engineers would thank you for all the time saved to be put to use on other pressing needs instead of a drafting cut and paste exercise.
Feedback accepted if anyone knows if this was activated already or if not, please help me press Bluebeam to get it done. I look to always work smarter and not harder. This seems like a no-brainer to me anyway…
Cheers
