in bluebeam max. if i'm copying a markup from one page and pasting on another page with a different scale. is there a way to keep the dimesion from the original page and auto adjust to new scale but keep original dimesion
Jorge, short answer: No, not the way you're describing.
Bluebeam treats measurement markups as two separate things:
- The physical size of the markup object on the PDF
- The measurement value calculated from the page scale
When you copy a Length measurement from a page scaled at 1/8" = 1'-0" and paste it onto a page scaled at 1/4" = 1'-0", Bluebeam will typically recalculate the measurement based on the destination page's scale. The displayed length changes because the markup is now living on a different scale.
Example
Original page:
- Scale = 1/8" = 1'-0"
- Line measures 20'-0"
Paste to page:
Bluebeam sees the same physical PDF line length but applies the new page scale, so the measurement value changes.
What you're asking for
You want:
- Copy markup
- Paste on new page
- Automatically resize the markup to match the new scale
- BUT keep the original measured value
Bluebeam does not have a native "maintain original measured value while automatically scaling to destination page" feature. The community has been asking for exactly this capability.
Closest workaround
The closest thing is using a scaled Tool Chest / Dynamic Tool Set Scaler:
- Save the markup to a Tool Set.
- Set the Tool Set scale to the source drawing scale.
- Place the tool on the destination drawing.
- Bluebeam automatically adjusts the physical size to the destination scale.
For your workflow
Since you're doing steel estimating and carrying data forward:
I would not rely on Bluebeam measurement values surviving between scales.
Instead:
- Store the actual length in a custom column (
Length_Final, Fab_Length, etc.). - Let the measurement markup remain a visual reference.
- When you paste to another drawing, the custom column keeps the original value regardless of scale changes.
That's actually more robust for your estimating → detailing → QC workflow because it separates:
- Drawing scale
- Measurement tool
- Actual production dimension
from each other.
If you're trying to carry a takeoff from bid drawings into fabrication drawings without remeasuring, I may have a better workflow using your custom columns and tool sets that avoids this problem almost entirely. That's getting into the stuff you've been building with your estimating engine.
