I create a lot of my own hyperlinks. When I create one the hyperlink window is much larger than the markup? I have to go in an manually adjust the hyperlink window each time to prevent overlap. A lot of my hyperlinks are stacked. Is there a way to set hyperlink window size in preferences? Or, save a hyperlink to tools with a specifice window size? This is my work flow for creating a hyperlink tool. Create Markup>save to tools>Right click and define action. I reuse the grafic with the hyperlink multiple times. I simply amend the action to point to the correct location? If there is an easier way, I would love to hear it. Most of my hyper links point to an cable schedule, or conduit schedule, from a conduit installation set. Just for a little insight into what I am doing. Unfortunately I cannot share the docs, as it is and Oil/Gas Client. They do not allow it. Attache screen shots show the overlap, then after I manually adjust it…
