Good morning everyone,
I’m currently using a Microsoft Surface Laptop (7th Edition) with an ARM-based processor, and I’ve been experiencing several issues while using Bluebeam Revu. I wanted to see if anyone else has run into similar problems or found solutions.
Here are the main issues I’m encountering:
- File Explorer Preview: Most PDF files are not showing previews in File Explorer.
- Graphics Not Displaying: When opening documents in Bluebeam, certain graphics or elements are missing or not rendering properly.
- Typing Issues: When using the text tool:
- The space bar does not function properly
- Text appears to type backwards
From what I understand, this may be related to compatibility issues since my device is ARM-based rather than Intel/AMD.
Has anyone successfully used Bluebeam on an ARM device or found workarounds for these issues? Any guidance, settings adjustments, or recommendations would be greatly appreciated.
Thank you in advance!
