Say you have a Base Bid set of documents that has multiple addenda set of drawings to slip sheet. If any of these addenda have the same page labels / regions in them (i.e., they were revised multiple times), you have to slip sheet each set to the original set individually, then do the next set, then the next…
It would be great if you could create a "list order" or something similar to use the same criteria to slip sheets multiple addenda sets into the single file, one after the others, so you don't run into the "duplicate page labels" issue.
