Can Someone explain these Red Clouds to me? Why do the Come up and what is the issue?
Thank you
These icons indicate that markups are pending upload in a Studio Session. My guess is that you are currently working offline, there is a Reconnect button in the Studio Panel, when you go back online all these markups should upload and the icons should go away.
Hello, I have used the Grab feature for years and it is one of my most frequently used tools. Recently, however, when I grab from one drawing and paste into another, the file size increases from around 1 MB to 2 GB. If I switch off “Take Vector Snapshots”, it resolves the file size issue and the drawing size hardly…
As part of preliminary estimating for roadway projects I have created a custom toolbox for area, length and count items. I can change the color. Is there a way to change the icon to something like SW for sidewalk area? I have the measuring tools set up with custom labels and layers to facilitate review and quantity total…
Hello, Can I import Chets Tool Items from Excel. I've a list of items in Excel (number, description, m, m2, m3 of Pc) I've to measure. Can I import it to Tool Chest. Thanks.
Good afternoon, I want to create a Tool-Chest component in "Tool Chest" that automatically numbers, e.g., W001, W002, W003, W004, ... and measures the area. It should place this on the plan-view with number W001 and the area. And then also place this number W001 in the Marksup list so that the link between a specific wall…
Hello! Today when uploading a capture from a screenshot, the image sets at 3D, does anyone know how to make the capture images to set at 2D? Thanks in advance
Hi All, I want to send selected sheets from my drawing Set to a sub contractor. Is there a way to send just the sheets I select from the Sets window? Thanks Ahead, Ian
I am estimator and sometimes need a lot of back and forth between plan and sections/details. I am aware of can use ALT+ Arrow left to back my previous page. But, I would like to keep focusing my current drawings and open those links trough new tabs. I can do it when I use Microsoft Edge (when have opened the PDF drawings).…
