Hello all, I am hoping one of you lovely people have had the misfortune to run into this issue.
Background:
I am using BB Complete 21.6.1 and others in my department are on varying other versions.
The markups were created by me in AutoCAD, then exported to a pdf where I would take a snapshot of the image to create my toolbox markup. I did have vector images enabled when doing this. I keep the toolbox on the server where everyone can import it so when a changes get made, those using that toolbox will automatically get the update if they open BB while connected to the server.
Issue:
After some time, a week or a month, we notice that the font used to create the images would change on its own inside the markup inside the toolbox resulting in unaligned and clipped text and an inconsistent appearance of the markups. They always seem to revert to the same font.
Attempts:
I have tried to test creating markups with vector images disabled but there is no way that is going to work. The markups do not resize well without blurring the images when they stretch. Also, with vector imaged turned off, snapshots are not matching the original image size. I will take a snapshot of something and when I paste it, the images will be 4x the size of the original for some reason. (this is likely an additional unrelated bug)
I have also contact support twice about this but only get a response that the issue could not be replicated even though I sent a pdf containing an example of the issues I am seeing.
