What's up community?! I am struggling with an efficient procedure to create bookmarks in bluebeam. I know how to create bookmarks and parent/child formatting. I want to know if it is possible to write a script or if a default method exists to have bluebeam create a parent bookmark such as electrical, mechanical, plumbing, etc and then for each section a child bookmark will be created for that division section.
For example, Electrical will be the parent bookmark and underneath it will be any available child bookmark per specification section such as 26 00 00, 26 05 16, 26 05 19, and so on (example image 1 below-manually created).
Right now I am manually clicking through each page, selecting the header of that page "26 2200 - LOW-VOLTAGE TRANSFORMERS" and using ctrl + b to bookmark it. There MUST be a more efficient method. When I select to create bookmarks based on region, I do not get a positive output (example image 2 below). When I select to create bookmarks by page label I am only returned bookmarks with the page number because a descriptive label does not exist.
