Our team would benefit from a configuration change of the Status column to allow an Author to edit or replace a value for a status they created. This capability would be available to each Author only for the statuses they created. Currently when an Author attempts to make a correction of a value they placed under the status column, the correction appears UNDER the erroneous value. It creates confusion and often results in the Author attempting to make additional correction(s) that are then placed UNDER the last value. Authors often repeat the step, inadvertently creating a stack of values under the Status column related to a single Comment.
