Hi BB,
Please make above window adjustable in size. I use fairly lengthy descriptions from our Winest estimating database (which has a max text length of 127 characters). Every now and again, I clear out the auto-complete list to remove any unwanted/incorrect entries however this is extremely time consuming as I have to select each entry and then select again so as to enter edit mode to see the end of the text. Even then I cannot see the full length unless I copy text (from edit mode) into a blank word document. Can you please make this window adjustable (or at least wider) so that it is easier to use? Thanks (in anticipation!)
MG
