Is it possible to add 1:250 scale to the program
Hi Bbannon, YES! While we don't have all possible scale options, you can add your own options (even ones for when the CAD operator 'prints to fit' and not to scale). Here is a LINK to our support page. I have shown the edited imperial measurements used in the support page, to show what Metric will look like for you. This will then be incorporated into the PDF drawing and any other person that opens it will see 1:250.
Once you have it +Add Preset, it will look like this. As a preset, it will only show on your installation of Revu; there is no option to share this as a 'setting' with other users.
