I have a client that would like to use the functions and features found in the Prime Portal.
Namely reactivating a finished Session.
Is this in the org. admin. portal?
If so how is it accessed?
Thank you
Vinnie Stamato
Hi @Vinnie .
Is this related to Bluebeam Cloud?
Asking because I am unfamiliar with this *portal* nomenclature.
I spend all my time in the Desktop version.
The Bluebeam Prime Portal is a BB admin site that retains the details of current, archived and finished Studio Sessions and Projects.
It's end of life is December 2025 and my question is how much will the Revu 21 subscription management portal handle this function.
I work for a reseller and my clients are asking about this.
Vinnie
https://support.bluebeam.com/studio/resources/studio-prime-eol-announcement.html
Our CSM said beta testing of the Studio management features in the Org Admin Portal start in June.
Last night, our Admin team nearly lost their minds. While converting 92 Word documents to PDF, they discovered that the new PDFs were displaying the old versions of the Word documents. Any ideas what caused this and how to prevent or correct the problem if it happens again? They converted perfectly this morning.
What’s the Best Way to Measure LF on a Curved Wall?
Hi. Is anyone experiencing their toolsets randomly removing the first item in the list and replacing it with another? For example, I can open a set and the first one in the list should be say a 3-pole plug, followed by a 4-pole, 5-pole etc. but for some reason the 3-pole plug has been replaced by something random from a…
I have noticed when saving a file as PDF from Word the are sometime several bookmarks listed as "1". Bookmarks are created using Word headers, but there are never any headers named "1". Does anyone know why this happens and how to prevent it?
Is there a way to add together measurements between multiple pages? Say I markup a ton of items as MTL-2 over many pages; is there a way to add them all together? Like the legend below but for all pages with MTL-2
Just did the update this morning. Everything went well except I no longer have the Revu icon. It is just looks like a piece of paper with the right, top corner bent over. Is this the new icon or did something not load correctly?
I did not see this before but lately yes - when you click File/Email on any open file, the email window opening up will have the file attached but the actual file name will have [1] added to the name looking like ***[1].pdf while the subject line shows the original file name. How can I stop this so the file name does not…
I am needing to make comments/remarks on CAD-based file with a lot of layers and small symbols and when i try to select a group of my comments it grabs these - what appear to be random - cad-based linework that came with the original PDF. They have gray grips and i cannot edit those. I understand that I can turn the…
Previous to recent versions of revu, holding the control key while starting a measurement/markup or anything that would trigger object snap would temporarily disabled it. This is extremely useful when you generally want object snap on but not right at that second, usually because of a dense area where there are so many…
Is there currently an option to enable a new tab opening when clicking on a detail hyperlink? This would be great! Currently I just split the view and then click the link, but this seems more straightforward for new users.
