@Christopher Castro, You can achieve this by applying a filter during export. Assign the items marked with “(1)” to a specific column, then either uncheck that column during export, or exclude them during the filter and sort stage.
Hope this helps!
@Shaya Birnbaum I think the (1) is a count BB adds to the list, not part of the "subject" like it could say Line (13) and then list thirteen line markups. Below is an example (different format) of (7) markups by "lshiras". Later there will be (29) markups by "Luke Shiras"
@Luke Shiras, Thanks for the clarification. I usually export to Excel, so I haven’t encountered this issue before. I tried manipulating the PDF export, but regardless of the setup, it still includes a “Total Count” heading. This problem doesn’t occur when exporting to Excel.
