Is there a way to select all items on all pages after mark-up? I need to have all items appear, from all sheets in a single legend.
Common mark-ups will all tally together, but if there is a stray item on a single page, it gets left behind.
I don't think that's a thing really. Could you maybe place duplicate mark-ups on the sheet with the legend, but just outside the printing area so the markups aren't "on" the drawing but they're still captured? I'm spit-balling here and not totally sure that would even work at all.
Go to your markup bar and multi-select (can just hit "ctrl+a" to select all markups in the bar) right click, add to legend
For the source of the legend are you selecting "All Pages"?
ugh I hate the placement of this setting, it took me so long to find it in the properties panel
Yes, I am. If a mark-up does not appear on the current page, it gets missed from the legend
Tried that. "Legend" is not selectable from there.
Should show on right click, just out of curiosity, what version of revu are you on? Is it any specific type of markup that's not populating?
And the first attempt the legend was created from the toolchest the tool came from? are you modifying any properties of the tool? i.e. changing the subject? Here are some snapshots of how it should normally be applied, how you would select the source, and also how you would manually add things to an existing legend. If all this is broken and you are on the latest version, you may need to re-install, but I have a feeling there is a detail were missing here.
Revu 21
Legend is not selectable.
REVU 21
