I wanted to removed all markups in my pdf so when I open it to BB it will apply the profile that i save.
How do I save a 3d model tree with just the columns that I choose? I have tried saving as a new view and then saving the pdf but when I open the pdf again the 3d model tree has reset to its defaults. I would like to send the pdf out to my team and clients so that they are able to just open without the need to set anything…
When I've zoomed into a document and want to print that particular expanded view seen on the screen, is there a way to do that?
How can I get permission to change my account's name?
I am currently doing takeoffs for trenching and I cant find a tool that will help me in one step. Is there a tool that I dont know of? Example a polyline tool with options to give it a depth a bottom width and top width for the sloped trenches. This tool would be a great help to calculate trench volumes.
Hi, how do i add or create a coverage area layover similar to this and scaled …Thank for any help
I have a document with over 30 text boxes that are polygon shaped. I need to keep the text the same and just change all the text boxes at once to a rectangle shape. Is there any option to do this? Any help would be greatly appreciated.
Bluebeam Support informed me that external scripting is a provided feature but not a supported feature so the only avenue for support is peer support. Searching the forum doesn't yield many results that would indicate many users are taking advantage of this feature but I guess that isn't surprising since it isn't…
I need to copy-paste formatted text boxes, and then edit it similar to this one: Is there a way to do it in Revu? I can only snapshot the text box (but can't edit afterwards). If I copy-paste, it keeps the text, but not the format, and I still can't edit. Any idea/trick?
