hello I'm new here. I am needing to use this program to find the square footage and the baseboard perimeter of a project that I'm bidding on and I have no idea how to add it to the app or how to make it work. Can somebody please help me?
Do you have a screen shot of what you're trying to accomplish? Might I suggest watching a few videos at Bluebeam University first before you start getting into using the software. It'll help
@HollyTalbot , switch your left side panel to thumbnail views, then right click on each plan you are working with and set the scale. Hopefully they are one of the PRESETs that are typical architectural scale settings, otherwise, you can use the CALIBRATE command (second one in the pic below). Once you have scale set, all these icons will provide measurements and values for your takeoff. Examples are the POLYLINE and the POLYGON that will give area and perimeter.
Follow these links to get started after setting the scale. Area tool: https://support.bluebeam.com/online-help/revu20//Content/RevuHelp/Menus/Tools/Measure/Area--MTV.htm Perimeter tool (Core and above): https://support.bluebeam.com/online-help/revu20/Content/RevuHelp/Menus/Tools/Measure/Perimeter--MTV.htm
The area tool will actually accomplish both. While the Area tool's primary measurement is Area, it gives other dimensions as well.
The Length of an Area markups is actually the Perimeter, plus it also will give you a height and a width.(just remember that the height will always be on the y axis and the width will always be on the x axis)
As you can see, if you set up your markups list properly, you can actually achieve both of your goals with one markup.
