Bluebeam is awesome for drawings etc., but it is not a web browser. Wouldn't it be nice if when you clicked on a web link it would open in your default browser? Unless there already is an option and I just don't know about it.
Hey @Luke Barlow - go into Preferences (Revu → Preferences or CTRL + K).
Try this:
Window → WebTab
Uncheck Open PDF Hyperlinks in WebTabs
OK
Now I don't know how to vote because both choices are the same result. 😁
Thanks Ryan
