When i try to edit the text by double clicking into the "Notes" column i created, an autofill box appears and i can't edit text. This is frustrating. Does anyone have an idea of how to fix this?
You should be able to edit the text within the Properties panel. Hopefully, this bug will be patched out with the next update.
That works. Thank you.
I want to group all WF Beams so when I click the beam for a take off it, has a pulldown to select the size. Can this be done?
I am having an issue where when I save, mark-ups just disappear before my eyes. I do a save after every sheet of mark-ups, and at random, every mark up I did just disappears. What is strange is that they still appear in the mark-up list, but that does me no good. I have tried exporting and reimporting the markups, doesn't…
Is it possible to relocate a drawing set from a laptop to a server? I have a large set with several revisions and would like to move it to a server to share to with others.
Perimeter measurement is an integral part of my work, however, is not available on my system (Bluebeam Revu x64 Basics). Is this correct and if so, what do I need to do to make this available. This is the only tool that I need (that is not available to me already) and I'm hoping that I do not have to upgrade my system to…
Whe I add a new toolbox, I am prompted for a place to save it. The default location, at least mine, is in the Windows user area. Something like C:/users/(your name)/AppData/Roaming/Bluebeam software/Revu/21. In my office we share files on One Drive. Can a default storage location be set so we don't have to climb up and…
Hi, Need to find out how to do a Global or Default setting for changing the current Measurment tool from inches to mtrs and font size, color of infill etc. Currently we have to go for every single take off measurements from changing this from Feet to Meters and rest of font size , color of infill etc. there must be a short…
Hi - new to the group. Confounded by this question. I am not able to print markups outside of the document area and the document. In print settings I am able to print either the document or the markups but when I click document and markups the markups are cut off at the document edge. I am making markups outside the…
hello I'm new here. I am needing to use this program to find the square footage and the baseboard perimeter of a project that I'm bidding on and I have no idea how to add it to the app or how to make it work. Can somebody please help me?
I have some markups that cannot be moved oredited after I change the linetype to a linetype that I created in bluebeam. Anyone have any answeres as to why this may happen
This past weekend I was working with some fillable PDFs from the Department of the Army (United States). Bluebeam was able to open the PDFs just fine, but signing them caused Revu to crash on me and it would say something about the type of file being unsupported. I ended up just downloading Adobe to sign those specific…
