I want to group all WF Beams so when I click the beam for a take off it, has a pulldown to select the size. Can this be done?
This should be a product request. I really am disappointed they have not implemented dynamic blocks in Bluebeam.
Can you explain what you mean by dynamic blocks?
In AutoCAD you can define a block with parametric parameters to drop into a file, it would come in matching the drawing scale, and then you could stretch it to the dimensions you want, click drop down options to switch between different types, or create an array with an input amount of objects. So for example a single button would drop in an anchor and you could switch between cast-in, wedge, epoxy, screw, undercut, then stretch it to the length and change the diameter all with the same dynamic block. You would only need one toolbox button for all the different sizes and types of a particular thing. One single block for every type of steel wide flange beam. One single block for every type of metal deck. etc.
Can you explain in a bit more detail what you are trying to do - what is the step-by-step process?
