When I create a polygon cutout within an area and then try to measure a sub-area within this cutout, a bucket fill function is activated, filling the entire area. Is there a way to disable this fill function so that I can manually define the edges of the area measurement?
Have you tried setting FILL COLOR to None in your properties panel?
Curious if you do that and then right click/set to default will your issue go away….
~j
