I have printed a set of plans that has over a hundred sheets and then I batched signed them. After signing them I realized one of the sheets did not print correctly so instead of reprinting the entire set again, or clearing the signatures one by one, I want to clear all my signatures with one quick command so I can swap out a sheet then batch sign it again with the new sheet. What is the easiest way to do this?
