I'm a building Inspector and at times for large plans I like to connect or align several pages so I can see the entire layout of MEP is there a way to do this in BB directly?
Hello, @jmkppf we discussed this in a recent post. Check it out and see if that solves your needs.
There were a couple of approaches discussed so read through the whole post.
