Is there a way to insert a single page pdf into multiple pdfs?
I need to update the title sheet of multiple pdf's. I insert the standard PDF then update a few of the text as needed.
While there isn't a Batch Insert function, I was able to come up with a workaround that may help. Feel free to give feedback or different recommendations if anyone has them!
What I did was use the Batch Slipsheet function.
Unfortunately, when I got to the Match Function, it wouldn't allow me to match one sheet to multiple locations. So I made duplicates of that sheet and then used the function and that worked out.
I chose Manual Correlation before Match Pages.
And manually attached each copy to the first page of each multi-page document I was replacing the title page on.
This did work, and I imagine would still save you time. But, you will still have to take the time to make the copies of the sheet you're looking to insert.
Keep in mind that Slipsheet may not be an available feature in your version of Bluebeam.
