Are you referring to these columns?
This discussion has been moved from Product Ideas to the Talk Bluebeam topic to gain more comments and visibility. However, this feedback has been recorded for our Product Team.
I would guess it to remove the "Comment Column" when toolchest items are in Detail mode. The comment column takes up valuable realestate and unable to open the Subject column wide to view easily without opening the whole tool chest very wide. @Willem Kraaij This would be a great fix.
When you click on 'Manage Tool Chest', select one of the existing Tool Chests and click 'Modify'.
From here, you can edit the name for each tool chest. You can also select the red "X" to delete the tool chest that are no longer used.
As far as the columns continuing to narrow, I do not have an answer for that. I agree with @Brent that the comments column should be removed or at least moved to the right of Label.
When working in the detailed view of the Tool Chest, I find the "Comment" column takes up too much screen space. Is there a way to hide or rearrange it? I’d like the "Label" to be more prominent instead.
This request has come up a couple of times. The answer so far has been "no" but go vote on the top link so they can see how much interest there is in this option.
@Marco M time to merge posts?
If you choose an area and set the color, line weight and so on, then click out of measurement you have to then go back and redo all the particulars for that item that you are trying to take off. Can this be remedied? Onscreen allows the user to set a group of items to use repeatedly throughout a set of drawings (color,…
Populous is hiring for a Computational Designer that sits on our Global Digital team. Link below to apply today! https://populous.com/careers?gnk=job&gni=8a78879e9c9ca640019cbacb46066ef9&gns=Recruiter
Is there any way to autogenerate markups in Bluebeam instead of manually tracing every area and perimeter? I bid multiple jobs a week, and these "robotic" takeoffs are a huge bottleneck. Does Bluebeam have an AI feature to auto-detect these boundaries and generate the markups? Manually tracing miles of sidewalk, asphalt,…
Imagine placing a door symbol and Revu automatically attaching a mini BOQ for leaf, frame, hardware and labor, all rolling up into one smart cost object that updates as you copy or move it.
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad? The image below is how you see it on Bluebeam for Web: The…
Curious if anyone adds a "time" or "man hours" columns in their markups list when doing takeoff. I have some ideas but unsure if they will actually be useful. For example: 10 LF of footing = 1 man hour. Does anyone have any tips on adding custom columns on their markups for time? I already utilize it for material cost per…
Hi!, I'm a senior technician in an architect office, and I regurlarly do some site surveillance and dificiency reports. I am looking for an app on a tablet to consult plans (pdf format ideally), annotate them with comments (ideally speak-to-text) that will generat a list of comments with a "pin" on the pdf plan localising…
Is it possible to extract data from multiple pre-defined locations on hundreds of scanned PDF's and extract/export to excel? Scanned pdf's would have same form and locations of information. I have been able to extract all of information on pages (creates mess) but no way to capture just certain fields/locations?
Good Morning Has anyone successfully imported their take-off from Bluebeam via excel into Trimble Contract Master Estimation software and have you managed to link an item in that take off to your database item?
