Did a quick search and found nothing. Maybe I am missing it, but is there a way to customize right click menu? Thanks in advance…
From my understanding, you cant bind anything from your mouse in the keyboard shortcuts menu located here.
If you like to customize your interface @JStanke FCI consider getting yourself a multi-button gaming mouse. I''m running with a "Logitech G502 Hero" corded gaming mouse. With this setup you can customize just about any of the buttons on the device - I have 6 custom settings on my mouse for use in Revu:
This mouse wasn't crazy expensive - they make some with more buttons/additional scroll wheels that are crazy and has helped eliminate multiple "clicks" from my workflows. I highly recommend adding one to your setup.
Hope this helps. 😎
I recently discovered a bluebeam file which included lines with line style to suit different type of steel sections. The way the line style worked is that if the the page was 1:10 scale and the line weight was 1.0, the line style would produce a side on profile of a given steel I beam to scale. I thought this simplified…
I erased one digit of the original pdf. Then added one character in text box over the erased area. Color is black. When I print, the character prints gray. And it looks gray in my "recents". (see "5" below) Anyone have a clue why?
I would like a .BTX file with all Electrical and AV Symbols in it. I would like to mark up plans for material Takes.
When using the highlighter to mark completed changes, it often jumps into "text" mode every time it goes over letters, etc. Is there a way to turn this off so I don't accidentally highlight a bunch of text? I know you can hold down the CNTL button, but I'd like something that works more smoothly.
I am interested in understanding how my team can utilize BBM in the field to perform construction punchlist with notes and pictures and how this data can turn into report. Ideally we would like to have a toolkit available. What is the timeline for this functionality?
I am trying to get or develop a way how I could get an automatic distance between two devices taking into account some parameters that I define
If I measure some items several times, and then an hour later find some more to measure, can I reuse the markups I used initially without adding to the Toolbox? I see there is a format painter but this just changes the markup appearance without changing the markup properties such as layer, description, etc. If I added…
I'm using the mobile app for iPhone and my project recently stopped updating all the changes I make on my laptop. I'm currently running back and forth taking pictures of different details and going back to the building to layout work for my guys. Is anyone else experiencing this issue? I hope it's something really dumb…
I am open to purchasing a higher license, but first I want to see if this will work like I am hoping it will. My company adds user data in a spreadsheet (e.g. IP Addresses, SN, etc), and we would like that info to go directly into our as built drawings. The idea being that we would only have to update the information in…
