Just did the update this morning. Everything went well except I no longer have the Revu icon. It is just looks like a piece of paper with the right, top corner bent over. Is this the new icon or did something not load correctly?
Are you looking to have a shortcut pinned to your taskbar @Tami R? Seems as if I've had to add that back in when I update the program. My pin shows up as the "round R" logo:
I establish this setting by typing "Revu" in the search box at the bottom of my screen, right clicking on the "Bluebeam Revu 21 App" at the top, and then by selecting "pin to Taskbar" (mine shows unpin as it's already there):
Hope this helps. 😎
Thanks. I had already had it pinned but unpinned and re-pinned and all is good now. Such an easy fix. Not sure why I didn't just do that in the first place.
This might be a really obvious one but I can't seem to figure out the best way to do this: I frequently mark up drawing sets for estimates wherein there are multiple pass-through trades under my scope. What I want to do is to be able to do takeoffs for multiple trades, giving them each their own layer that represents them,…
Need help with my cursor and measuring tools. My cursor will only go in a straight line in the measuring tool I am unable to follow a radius or use the measuring tool correctly, it will not follow the cursor but only go in straight lines.
Last night, our Admin team nearly lost their minds. While converting 92 Word documents to PDF, they discovered that the new PDFs were displaying the old versions of the Word documents. Any ideas what caused this and how to prevent or correct the problem if it happens again? They converted perfectly this morning.
What’s the Best Way to Measure LF on a Curved Wall?
Hi. Is anyone experiencing their toolsets randomly removing the first item in the list and replacing it with another? For example, I can open a set and the first one in the list should be say a 3-pole plug, followed by a 4-pole, 5-pole etc. but for some reason the 3-pole plug has been replaced by something random from a…
I have noticed when saving a file as PDF from Word the are sometime several bookmarks listed as "1". Bookmarks are created using Word headers, but there are never any headers named "1". Does anyone know why this happens and how to prevent it?
Is there a way to add together measurements between multiple pages? Say I markup a ton of items as MTL-2 over many pages; is there a way to add them all together? Like the legend below but for all pages with MTL-2
I did not see this before but lately yes - when you click File/Email on any open file, the email window opening up will have the file attached but the actual file name will have [1] added to the name looking like ***[1].pdf while the subject line shows the original file name. How can I stop this so the file name does not…
I am needing to make comments/remarks on CAD-based file with a lot of layers and small symbols and when i try to select a group of my comments it grabs these - what appear to be random - cad-based linework that came with the original PDF. They have gray grips and i cannot edit those. I understand that I can turn the…
