Hello,
Lately I have not been able to Uncheck the Custom Column Check box's in the Column Display Order. I am able to Check and Uncheck the Built-In but, Not the Custom Columns.
@Phil Berania Thank you for your feedback. We have received input on this matter and are exploring ways to make it more intuitive. Currently, you can toggle these columns on and off via the dropdown menu in the markup list.
Hello Glynis,
Yes Maam I understand that. However, That only Turns off the Columns in the Mark Up list area. It does not Close the Columns in the Properties Menu.
Where did the default page navigation arrows go? How do we get Revu to go back to the default page navigation interface? What did we do to make this change to the Revu UI? Default UI Current UI
Hi everyone, I am a Building Surveyor and use bluebeam when I'm undertaking audits of existing buildings that are later put into Building Code reports. The system is amazing for what I do, but just generally I need to put photos into emails and reports where its easier to just grab the photo and put into our reports…
Hi, I want to use the textbox markup to type in the Farsi language, but it shows separated and backward. How can I fix this issue?
Hello, I'm looking for a 3-party System/Vendor that we can use to backup the entirety of our Studio contents (across all Users/Projects). One that an BB Admin could use that allows visibility of all Users/Projects/Data/Folders/Files being stored under our Company/Licenses; and simply be able to backup everything from the…
Issue with Revu 20. Opening the program window will not allow me to move or drag it. No close or minimize buttons in the top left corner. No Revu , File , Edit , View, Document , Batch , Tools, Window , Help
Hello, Is it possible to have Bluebeam Studio automatically sync all studio files to a local server in lieu of Bluebeam's cloud servers? My office is exploring the idea of getting all of my project observers an iPad with cellular data so that they can have Bluebeam Studio (or rather Bluebeam Cloud) at all times. Should…
Hi, we mainly use Revu 21 to edit pdfs and save in PDF/A format. We need pdf documents in PDF/A-2b format. Is it possible to convert a pdf to pdf/A-2b format? please explain how to do it? thanks Oliver
Our IT department has been slowly upgrading our users to Windows 11. A few of our users have been experiencing really bad lag with creating, moving, modifying markups. This happens both in Session and with locally saved files. It seems to only be happening to our users with virtual/cloud computers. Specifically, we use…
What is up with the invisible text while editing a markup? This has been a recurring and persistent phenomenon that has remained through several updates of the BB subscription, over perhaps the last year. I create a markup with text, I double-click to edit said text and it becomes INVISIBLE (but is still there). I click…
