BB crashed and I had added/edited dozens of tools and when I logged back in many of the toolsets were not showing in my profile or in the toolset list (so not hidden). Any ideas?
And when I tried importing it said they already existed….
Have you shared your logs with Bluebeam support yet?
No, tried opening support and it wouldn't load.
Shot in the dark, but I noticed sometimes when I restart revu, it kicks me off my profile and resets me to default. Acts the way you describe. Try making sure the correct profile is set.
Thanks, I did. Restarted, logged out & in. All the usual "fixes" ;P
Between the profile and the support function not working, this might be a re-install situation. You can try going to the folder "C:\Users\[your name]\AppData\Roaming\Bluebeam Software\Revu\21". This is where all the toolsets are stored locally. You can manually delete them here, as well as the old profile and reload it, but I have a feeling you might run into this again. I am sure the suggestions from support will include wither reinstall, rebuild profile from scratch or both.
Yeah, was going to try a re-install. Fingers crossed. Keeps telling me they are already installed when I try to import, but they aren't showing up. Thanks.
I have run into this issue before. I can't explain why this happens on the backend, but it's because Bluebeam crashed and you did not close the program normally since adding the new toolsets. I believe there is some process that runs when you close Bluebeam that overwrites a configuration file with the latest list of Bluebeam toolsets to load. Since it crashed, it did not have the chance to overwrite the file with the new list, so it reverted to the last one before the crash. And the reason it said they already exist when you tried importing, is because they do physically already exist in your native bluebeam tool set folder - you added them there last time before the crash, but Bluebeam "forgot" since it could't rewrite the configuration file. That's my general understanding - may not be exactly technically correct. The way to avoid this problem is every time you add a new toolchest/toolset, make sure to close bluebeam normally because otherwise the next crash will cause the issue.
when exporting a table to excel, it turns part of the table into an image with a black rectangle
Now that the option to switch from Markup mode to View mode has been removed from Revu 21, is there a way to lock markups and comments so that you don't accidentally move or shift them while panning around in the file?
How would you remove hyperlinks in a document on a mass scale? Not going to each one and changing it's action, but listing all hyperlinks in one location and removing all in one fell swoop. I've looked thru the markup list to see if there was a way to display a list of all the hyperlinks in the document, but it doesn't…
Hello - When clicking on an established session I have been in before I get the spinning wheel then popup "Your connection to studio has been lost". After clicking OK closing window, it does open the session except it has "disconnected" me. Also does not show that in the Record that I have ever opened the session and any…
Is there any way to change the default from feet and inches to decimal feet? IT is a pain to change it every time I need a dimension. It did not used to be locked into feet and inches.
So , my question is that i'm noticing that the tools in the toolchest will automaticly rearange themselves in a surtain order. I believe only a few updates back this was not the case or a lot less. I could be mistaken as i,m still a relatively new user. Is it not possible to keep your tool in a surtain order and they dont…
I just updated to Revu version 21.7 and the tool that I used to snap dimesnions in length is now very wonky to use. It pulls fom the corner and not the centerline. Is there any way to revert it back to the previous version without abandoning 21.7 altogether?
Is there a Tool set for Audio-Visual? I use Revu for marking up drawing sets for the addition of A/V. I need to add things like data drops, electrical outlets, speakers, microphones, wall mounted monitors, etc. Does something like this exist in Revu? I have looked and cannot find a Audio-Visual specific tools.
Hoping someone can help me, or at least tell me I'm not crazy. I'm creating a stamp that when applied to the target document, will include a list of names that were entered in a dialog box, and then overlay a digital signature field on top of each name. Everything works except that I can't get the size of the stamp to…
Hi everyone, Just updated to the latest version and the "resume sequence" function is not working anymore. Anyone experiencing the same? Is there a way around this issue? Have the old version on another computer, the function works fine there on the same document
