how do I link my excel spreadsheet to bluebeam for takeoffs
you need to have Complete if you want to use Quantity Link. (Extreme if using Revu 20) There should be a tutorial in Bluebeam University.
New to the community, so hopefully I am asking this in the right place. I use Revu for creating pdfs with specific custom icons for different cameras placed on my drawings. In many cases, I have a project that will run multiple phases, with the desire to have each phase on a separate page. I would like to have a legend on…
Hello Eveyone, I am new to this bluebeam tool. I would like to know on how to make a 3D PDF extracted from the microstation. thank you for your response in advance,
What is the difference with spaces and places?
Is there a way to reorganize form fields in Bluebeam Revu so they follow the correct tab order when filling out a form? Right now, whenever I add a new field, it gets added to the bottom of the list in the Forms panel. For example, if I originally create fields "Text 1" and "Text 3", then go back and add "Text 2" between…
This morning, I read the latest tip and trick post with custom statuses. I edited a status, and then I created a filter which dimed out the markup once it was set. My question is, Is there a way to save a predefined view of the markups list for when I am going through revise and resubmit drawings?
When I type a number and try to move it it rotates and I can't line it up the direction I want it to be. Why / how do I keep it from auto rotating?
I have one user, in one PDF, when he click on the screen, the page advances. He's unable to do markups because the page keeps advancing. I've never seen the behavior and we can't replicate it. It doesn't happen to other PDFs in the same sessions and reoccurs if Bluebeam is closed and reopened.
Do Bluebeam Release installs come standalone? or Do you have to be in Bluebeam to install the latest update?
Hi all. Relative noob here. I have a single sheet that I printed from a 100 page planset that I need to edit. I printed the 1 sheet to a pdf in order to keep the file size small. I have added a couple of layers for my edits and want them printed red. However, all the planimetrics, utilities, topo I would like to print in…
