Since it looks like there is no way to unflatten a form field I am wondering if there is a way to lock one. So far I am not able to get it to work.
Thanks
There are several options, Lock will keep it in place and the properties will be locked but still able to be modified. Read only will keep people from modifying it. Visibility settings can hide it. Putting it on a layer and disabling, or even setting it to be off by default is a way to keep it out of the way as well. The last two options are pretty similar, in that the fields still exist, but you just can't see them unless you go into form selection mode. Personally I like the layers because I can use JavaScript to turn the layers on and off with buttons.
Hi, Im locked out of my account. Could you please reinstate my account as we have made payment and I have been on hold on the phone for an hour today and 30 minutes yesterday to no answer and i can't get through to you via email. Thanks,
Is it possible to extract data from multiple pre-defined locations on hundreds of scanned PDF's and extract/export to excel? Scanned pdf's would have same form and locations of information. I have been able to extract all of information on pages (creates mess) but no way to capture just certain fields/locations?
Populous is hiring for a Computational Designer that sits on our Global Digital team. Link below to apply today! https://populous.com/careers?gnk=job&gni=8a78879e9c9ca640019cbacb46066ef9&gns=Recruiter
If you choose an area and set the color, line weight and so on, then click out of measurement you have to then go back and redo all the particulars for that item that you are trying to take off. Can this be remedied? Onscreen allows the user to set a group of items to use repeatedly throughout a set of drawings (color,…
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad? The image below is how you see it on Bluebeam for Web: The…
Hi!, I'm a senior technician in an architect office, and I regurlarly do some site surveillance and dificiency reports. I am looking for an app on a tablet to consult plans (pdf format ideally), annotate them with comments (ideally speak-to-text) that will generat a list of comments with a "pin" on the pdf plan localising…
Curious if anyone adds a "time" or "man hours" columns in their markups list when doing takeoff. I have some ideas but unsure if they will actually be useful. For example: 10 LF of footing = 1 man hour. Does anyone have any tips on adding custom columns on their markups for time? I already utilize it for material cost per…
Is there any way to autogenerate markups in Bluebeam instead of manually tracing every area and perimeter? I bid multiple jobs a week, and these "robotic" takeoffs are a huge bottleneck. Does Bluebeam have an AI feature to auto-detect these boundaries and generate the markups? Manually tracing miles of sidewalk, asphalt,…
