I wanted to removed all markups in my pdf so when I open it to BB it will apply the profile that i save.
@Alger, There are several ways to remove your markups:
To delete them: Simply select the markups either directly on the drawing or from the Markups List, then press delete.
To hide them without deleting: If your markups are assigned to specific layers, you can hide those layers and lock them. This ensures the markups won't display or reopen automatically the next time you access the drawings.
Hope this helps!
You may need to open the document in Bluebeam to remove all markups. To do this, open your markup list, select all the markups, and delete them. Then, save the document as a new file. Additionally, flatten the document before saving it. After closing the file, reopen it, and you should have a clean file to work with. Alternatively, you could try opening it with a different profile setting and then reopening the file *Hopefully that helps.
You can also right click and select all, then delete (Ctrl+A)
CAn we export form Bluebeam to DXF. If not any way we can export the lines to be used in anlaysis software
Some of the consultant drawings I receive have a protected scale and when taking measurement and areas it doesn`t show up in the markup list. Also the drawing is blued out. Is there away around this Many thanks Murray
I've been trying to find anything related to this, but all I see is default tool 'settings' but I want to change the tool, not settings of the tool. The default selected now is the pan tool but my most used tool is the select text tool and when I open a new PDF or have multiple opened and then I close one, Revu will change…
Hello, I have used the Grab feature for years and it is one of my most frequently used tools. Recently, however, when I grab from one drawing and paste into another, the file size increases from around 1 MB to 2 GB. If I switch off “Take Vector Snapshots”, it resolves the file size issue and the drawing size hardly…
When working on a file, Bluebeam will freeze then shut down. It's been happening quite frequently. Why is this happening?
As part of preliminary estimating for roadway projects I have created a custom toolbox for area, length and count items. I can change the color. Is there a way to change the icon to something like SW for sidewalk area? I have the measuring tools set up with custom labels and layers to facilitate review and quantity total…
Hello, Can I import Chets Tool Items from Excel. I've a list of items in Excel (number, description, m, m2, m3 of Pc) I've to measure. Can I import it to Tool Chest. Thanks.
Good afternoon, I want to create a Tool-Chest component in "Tool Chest" that automatically numbers, e.g., W001, W002, W003, W004, ... and measures the area. It should place this on the plan-view with number W001 and the area. And then also place this number W001 in the Marksup list so that the link between a specific wall…
Hello! Today when uploading a capture from a screenshot, the image sets at 3D, does anyone know how to make the capture images to set at 2D? Thanks in advance
