The ability to have two separate Legends for the same Count/Markup. The ability to use the same tool set to count (2) separate drawings located on the same page and create two separate legends
Hi Jacob,
There is a way to do this - you need to setup a way to differentiate the counts. I included an example using your drawing and Legend but I added two spaces (you can find more info on spaces here) and called them Unit A and Unit B. I added a column onto each of the Legends by changing their properties to include the "Space" column (like in the screenshot below). This now allows me to have Electrical Duplex counts in each space that get counted separately. You don't necessarily need to use Spaces, but they're the most logical way to divide the counts on the sheet. Hoping this fills the need!
Thank you! Now how would I do the opposite? I have two counts that were started separately (not resumed), can I merge the two counts together?
I think it would be useful to have a tool to mark several/all pages in a PDF with a watermark. In my specific case, I'm trying to note that a specification in a project manual still needs updates, but to do so in a manner that looks polished and professional. If a tool like this already exists, it would be useful if it…
Everytime i start a new pdf the first thing I have to do i change it to Fit to Page so I can see the whole pdf.
Revu is powerful, but lacks the ability to configure/save Workspaces for specific tasks. As example: Markups The native dock location (bottom) for Markups is not very user friendly. Yes, I can drag it out and position on the side, so I can still see our 24x36 (ARCH D) engineering plan sheets, but it has several issues.…
I have been using Revu to build quantity take-offs for construction estimates, I’m trying to clean up the organization and structure of the markups. I typically sort the markups by the subject, but I need to be able to re-sort the line items before I export the take-off. I can’t manually move items on the markup list up or…
Good morning, I logged a ticket with support but no response yet. I cleared the registry by doing a complete uninstall of all previous versions and used the Bluebeam Cleaner Utility (but that only goes back to 21.0.3. I also ran the latest download as an administrator yet the only thing that installs is OCR and when it…
Hello, recently I have encountered an issue regarding certain snapshots and their interactions in other PDF viewers after flattening. When documents flattened in Bluebeam Revu are opened in Adobe Acrobat, snapshots that were previously flattened are able to be selected and edited. Is there a way to have snapshots flatten…
