We have over 600 custom words. Revu allows you to add them one at a time, but it would be great if there was a way to bulk import the list of words.
You should be able to do that by creating a .dic file. I haven't done it myself so it may require an .aff file as well.
This discussion has been moved from Product Ideas to the Talk Bluebeam topic to gain more comments and visibility. However, this feedback has been recorded for our Product Team.
Everytime i start a new pdf the first thing I have to do i change it to Fit to Page so I can see the whole pdf.
Revu is powerful, but lacks the ability to configure/save Workspaces for specific tasks. As example: Markups The native dock location (bottom) for Markups is not very user friendly. Yes, I can drag it out and position on the side, so I can still see our 24x36 (ARCH D) engineering plan sheets, but it has several issues.…
I have been using Revu to build quantity take-offs for construction estimates, I’m trying to clean up the organization and structure of the markups. I typically sort the markups by the subject, but I need to be able to re-sort the line items before I export the take-off. I can’t manually move items on the markup list up or…
Good morning, I logged a ticket with support but no response yet. I cleared the registry by doing a complete uninstall of all previous versions and used the Bluebeam Cleaner Utility (but that only goes back to 21.0.3. I also ran the latest download as an administrator yet the only thing that installs is OCR and when it…
Hello, recently I have encountered an issue regarding certain snapshots and their interactions in other PDF viewers after flattening. When documents flattened in Bluebeam Revu are opened in Adobe Acrobat, snapshots that were previously flattened are able to be selected and edited. Is there a way to have snapshots flatten…
I'm currently working on customizing the engineering review stamp from the custom libraries, but I'm having trouble figuring out how to edit it without disabling the pop-up feature that appears when placing the stamp. Ideally, I want the pop-up to remain active so that the reviewer can fill out the required fields…
