Hi all, is it possible to set a circle measurement to a specific radius or diametre? rather than having to click and drag to adjust? IE is there an input box that allows me to add a length as the one with the tool is greyed out
Thanks
It is a little counterintuitive but click Ellipse Sketch to Scale. If there is not a scale set for your sheet, it will first prompt for that. Then, enter the radius. The product is a circle that can then be modified to make an ellipse, or all manner of curvy Salvador-Dali-like-shapes.
or take a radius/diameter measurement
simply double click on the text of the measurement. You get a box with the measurement. Click on the value and change it to the radius you want to obtain. close the box and magic happens.
or as mention by Jes, use the Sketch function to define from scratch the radius.
I have plotted two drawings from AutoCAD to PDF (each a single page). When I open them separately in Bluebeam, their layers show up as expected. When I insert the second page into the same PDF as the first page, the layers are no longer showing for the second page. How do I get the layers to come along with the PDF when I…
Did a quick search and found nothing. Maybe I am missing it, but is there a way to customize right click menu? Thanks is advance…
What is this icon in Studio Session? How do I address it? Clear it?:
is Bluebeam going to add more tools to the cloud based app? such as stamp, measure/dimension and count.
My autofill descriptions list for the Count Subject has grown too big. When I begin to type in the Subject field of the "Count Measurement Properties" I get a list that is too big. I would like to clear this suggestion list. They are not "Subjects" that I have used in current PDF I am working on. They are the combined…
Hello, I received an email from Bluebeam stating that I was a part of their beta testing community. I have explored the new features, such as offset and markup conversion, but I haven't found the AI prompt capability. Is this available with BluebeamMax beta? I have paid subscriptions for Bluebeam (premium) and Claude.…
Hi all, I've recently been following the hype about working out of Bluebeam Sets as I'm looking for ways to streamline our workflow. I did have a question about viewing markups particularly when you are working with individual extracted drawing files as that seems like it gives you the best performance when working off of…
We are using the Revu version from 2015. We have yellow imbedded links in our PDFs that point to other PDFs. The only way these links work is if we have the folder where they are stored turned onto IE Mode. We want to get away from using IE Mode with Edge. Can someone help guide me through the process?
If I open a PDF that Does not have editable fields and I want to create one I would normally click the area then type and then click to the next area I want a text field. For some reason when I click an area to add a text field it allows me to enter text as normal, but once I click off of that area whether it is on a…
