Making BlueBeam Cloud a USABLE app
Seeing as to how many rave reviews there AREN'T for Cloud, I wanted to come on here and list a few features that are desperately needed, and see if anyone else has insight into how the mobile version can be made as awesome as the PC version: Undo/redo button - Honestly can’t believe this is not there… dynamic editing of…
Detached Tabs Still Not Independent? Posting for Awareness and Community Push
Hi all, I am posting to check if there has been any changes with support for fully independent windows when dragging tabs out. When I drag a tab away from the main window, the new window does not have the full toolbar, and minimizing one window causes both to minimize. I know I can open a new instance from the taskbar, but…
Locking Toolchest
Good lord why isn't there a way to lock the tool chest. Why are tools jumping around from section to section. I am not doing it, it actually wont let you move tools the way that it is moving tools around by itself. Sooo frustrating knowing that you have built a tool, to find it missing and then to re-find it in an entirely…
Save Job before Exiting
I often use Revu to combine documents into one PDF. Revu always asks if I want to save the stapler job before exiting. I never want to save the stapler job. Is there a way to stop that "Save Job before Exiting" popup from coming up?
Custom Column with logic
I would like to create a custom column that will give me either one of two choices. 4x8 or 4x10 based on logic. Is this possible?
Help? - Quickly/Easily File>Export>Excel Workbook>Page Region
Is there any work-around to no keyboard shortcut for exporting a page region to Excel? I have made several (unsuccessful) attempts to figure out a way to pin this function to a toolbar, but this does not seem possible either. Is there a feature that I don't know about that will allow me to simply add this shortcut, or add…
Combining the Length Measurement Tool with a Shaded Rectangle.
Hello peers, My goal using BB is to create excel spreadsheets of the counts of Exhaust Fans, Grilles, equipment etc. But most importantly ductwork. Instead of using the measurement tool where it gives you red measurements inbetween two arrows, is there a way I can highlight the duct run and it store the measurement?…
Right click>Look-up
Is there a way to change the search engine used when I look up text from a file?
Markups become opaque when measuring
In the latest update 21.7, semi-transparent or "highlight" markups are completely blocking out the content when measuring many documents. This creates more work if I have to guess a point location then remember to come back and fix it. I've been using BB for more than 10 years and the markups have always respected their…
Markup Custom Columns
Feel like I'm losing my mind. but I save my custom column to profile but every time I bring in a new PDF it removes it. What can be causing this. I have saved my profile and custom multiple times a day
