I think the problem here is that the precision is too precise when using dimensions. So you end up with measurements like 30.007 when using 1/8 precision (US units, but it's also an issue with SI units)
When rotating, the angles will snap to every five degrees unless you hold down shift. So the dimensions could behave similarly, snapping to every one degree unless you hold down shift.
