Hello - there was an update that rolled out I want to say in April - June that changed the behavior of selection. The feature that allowed you to select your markup if you hold shift - and while holding shift and pressing Space you can select through them. Since this update the selection behavior of Curves specifically have been maddening to deal with. I actually use a lot of curves in my markups - and before this update they were pretty easy to just select and manipulate. Now you have to be so specific with where you cursor is while selecting - especially if you have multiple curves in the same area. Just trying to move a curve around another is an extremely painful process. I encourage the Bluebeam dev / community team to just try this simple thing out. Creating a compound "S" curve used to take me several seconds. Now it is 5-10 minutes just due to the selection behavior. As stated - quite maddening. Unsure if this is a problem with others but a rollback on this would be beautiful.
