Placed a Polygon, Cloud, or Polyline and realized the shape needs to change — not just move or resize, but actually reshape? You don't need to delete it and start over.
Control points let you reshape a markup directly.
➡️ Here's how:
- Select the markup to reveal its control points.
- Click and drag any control point to reshape that part of the markup — connected line segments resize automatically.
- Need a new point? Hold Shift and click on a line segment to add one.
- Need to remove one? Hold Shift and click the control point you want to delete.
Bonus: right-click any control point and select Convert Control Point to Curve to turn a straight corner into a smooth curve.
➡️ Helpful article: Working with control points
👇 Share below!
- What kind of shape do you find yourself reshaping most often — property lines, odd rooms, something else?
- Have you used the curve conversion trick before?
