When I select a comment to change the status, the context menu disappears and I cannot change the status of a comment. I cannot change the status of my own comments, nor ones that others have added. What is going on?
I found a working solution: Change profiles from the "Revu" menu at the top left of the window. I switched between one of my 4 profiles and everything worked fine.
I also have the same issue. The rest of the custom columns that were added are grayed out, so no input can be inserted.
Many features are locked within a Studio Session. In fact, the only two columns in the Markups List that you will be able to make changes to (unless you created the comment) will be to Reply to a Comment or to change Status. (We have a 10-step internal checklist of things to review prior to loading files into a session because of how restrictive sessions are.)
Status - okay so this part is confusing, but bear with me. The Status states are part of status models. Which models are turned on will control which ones you are seeing in a Studio Session. If you have custom statuses, those need to be added to each pdf prior to it being uploaded into a Session. If you are not seeing any at all, the out-of-the-box models are probably turned off. To try to fix this, open any file outside of a session. In the Markups List, click on the 3 bars at the end of the column heading and select Manage Status. In the dialog box, check the box in front of the desired models to turn on. If you select Review and/or Migration, those models will then show in your session files. But any custom models will only show up in the session files if those models were added to the metadata of those files prior to upload.
How does one add custom models to a file you ask? The easiest way it to save them to a profile. If that profile is the active profile, the custom statuses are added to pretty much any file you touch - as long as you save. The other way to add them in, that we have found, is to create a file that has them in it (like one you created status models in) and insert that file into the pdf without status, save, and then remove that file (so preferably a single page). Keep that file around to be able to use to manually add status models as needed in future.
I am referring to the individual status of the comments made in the PDF by myself and other commenters.
The other challenge is if you are sending a file from Project to the Session for review in which case you have to pre-load the file in Project with the statuses for them to carry over.
Yes, the Revu profile has the default statuses active so then you would see them in your session, but you may not have access to the tools that you need
