What's the benefit of Filter and Sort? Specific detail and why its grayed out. Is it based off of subscription level?
Hi Joe,
Yes, it's related to your subscription level. The Filter and Sort option in PDF Summary is available with the Complete and Max plans.
It's actually quite useful because it lets you control exactly what appears in your PDF report. For example, you can filter markups by author, status, or other columns and sort the results in a specific order.
You can check your current plan by clicking your account in the top-right corner of Revu.
The good news is that you can still filter and sort directly in the Markups List with lower subscription levels, even if the advanced PDF Summary options aren't available.
Out of curiosity, what type of reports are you trying to create? There might be another way to achieve what you need without upgrading.
Using the Markups List - PDF Summary export, I need to be able to individually show all Mark Ups that are grouped.
Thanks for clarifying!
Just to make sure I understand, you'd like every individual markup inside a group to appear as a separate entry in the PDF Summary, rather than the whole group appearing as one item. Is that correct?
One workaround might be to ungroup the markups in a copy of the PDF before generating the summary.
But ideally, would you prefer to keep everything grouped in your original drawing and still have each individual markup listed separately in the exported report?
I'm curious because I'm exploring ways to improve Bluebeam reporting workflows, and this sounds like a genuinely useful feature.
A Grouped Markup doesn't export the individual parts to it.
That being said, I have a workflow that will do this, BUT there are a few caveats. #1 - you have to be REALLY good with Excel because its a bit of Excel Magic that pulls it off #2 - I've only even tried it with measurement tools #3 - its not really a Grouped Markup
Is there a reason that your markups are Grouped in the first place?
Hi Doug,
Thanks for jumping in and sharing your experience!
Just to clarify, I'm actually looking into Joe's problem rather than dealing with grouped markups myself.
I'm exploring whether it's possible to create a simple tool that would let users keep their markups grouped in Bluebeam while exporting each individual component as a separate entry in a PDF Summary or Excel report.
Your Excel workaround sounds interesting. Does it allow you to extract the individual measurements and their properties, or does it require some manual preparation?
I'm trying to understand the limitations before developing anything. If there's a way to simplify this process, I think it could be useful for other Bluebeam users as well.
Really appreciate your in
@Doug McLean Do you have any posts about how spaces can be used other than for grouping items the same location? How do you use Spaces to create an assembly?
Post? Not here. There is a guest Blog post on it over at UChapter2 however. https://uchapter2.com/it-all-started-with-an-email-a-guest-post-by-doug-mclean-of-towne-millwork/ There may also be a USBUG meeting video somewhere where I talk about how to use Spaces for things other than a Punch List. Spaces are designed for grouping items in the same location, all you have to do is activate them. There is an imbedded Column for Spaces in the Markups list. When you activate it, you can now sort by your Spaces and everything within that Space will be 'grouped'.
I use this all the time in my workflows. I will create a Space around an Elevation of something, and now that instantly becomes an Assembly. You can use the same technique on a Window frame, or… it doesn't matter, and because they're inside a Space rather than a Group all the different markups will actually export, or can be filtered in other ways if you so choose. Bluebeam teaches that Spaces can be used for Punch Items… let me tell you, they can be used for a whole lot more. They're an organizing tool. Have fun with them
I concur with Doug.
Spaces are wonderful organizational tools. I use them for buildings on site plans, floors plans, single rooms of a sheet, details and elevations, the list goes on.
Another neat trick is that you can nest spaces inside of other spaces and Revu will keep everything organized.
Doug's suggestion about Spaces is really interesting, especially since it allows individual markups to appear separately in reports.
I'm curious, though: do you specifically need to keep your existing markups as actual Bluebeam Groups, or would using Spaces instead work for your workflow?
I'm exploring the possibility of developing a simple tool that could extract individual components from grouped markups without modifying the original drawing.
Would something like that be useful to you?
Thanks, Madalin
